replacing ps pump belt
Loosen the tensioner bolt then the bolts holding the pump to the pump bracket. Keep loosening the tensioner bolt until you can slide the belt off the pulley. Install the new one is reverse order. Put tensions on the belt so you can push the belt 1/4" if the space between pulley's is around 7 in. and 1/2" if the space is around 13 in.
OKhonda94
Aug 9, 2010 07:31 PM
TWDDS
Oct 26, 2009 10:18 AM
