replacing ps pump belt
Old Jun 11, 2008 | 05:23 PM
96cordv6
Default replacing ps pump belt
need info on replacing the ps pump drive belt on a 96 accord v6. a manual or instructions on the steps i need to take to remove the old belt.
thanks for the info
Old Jun 11, 2008 | 05:27 PM
finch13's Avatar
Default RE: replacing ps pump belt
Loosen the tensioner bolt then the bolts holding the pump to the pump bracket. Keep loosening the tensioner bolt until you can slide the belt off the pulley. Install the new one is reverse order. Put tensions on the belt so you can push the belt 1/4" if the space between pulley's is around 7 in. and 1/2" if the space is around 13 in.
maestro1024
Mar 20, 2011 09:17 PM
OKhonda94
Aug 9, 2010 07:31 PM
TWDDS
Oct 26, 2009 10:18 AM
tajmag
Dec 3, 2008 12:26 AM
ksar
Oct 17, 2008 09:27 AM
