Replacing shift solenoids Honda Accord 91
Old Feb 1, 2014 | 07:46 PM
smabuki's Avatar
Default Replacing shift solenoids Honda Accord 91
Hi,
I bought a Honda Accord EX (91) for little money (student) two weeks ago and haven't had a good time since then. At some point the car would rarely/not shift in the second gear. In general, it shifts super hard. I had a speed sensor code so I replaced the speed sensor. For most of the time it shifts now, but sometimes the weird behavior comes back and it would rarely shift in the second gear (only at really high rpm). Last time this occured the dashboard signaled a bad brake light
I bought used shift/lock up solenoids and would like to replace the old ones to see if this might fix it. Unfortunately, I'm not very repair-savvy and don't know how to reach the shift solenoids. Can I remove the two pipes on the photo? Not sure if they are full with cooling fluid. I would be very thankful for a hint.
Best
Alex
Old Feb 1, 2014 | 08:02 PM
Socket extension can be used to reach the bolts. Flex sockets may or may not be needed, those bolts look accessible without flex sockets.
Those are the automatic transmission fluid cooler lines, ATF runs through them.
Not sure if you seen this link before; but, faulty resistors and/or capacitors in the transmission control unit (TCU) were sometimes known issues. The link has info. regarding the solenoid valves too.
Honda Electronic Transmission Problem- Troubleshoot, Inspection, Repair, Replace.
Old Feb 20, 2014 | 03:46 PM
smabuki's Avatar
Thank you so much. Will try to fix it this weekend. The problem now is also that it sometimes when it shifts from the first to second gear it starts slipping and does't get into the second gear. Doesnt happen every time. That transmission drives me crazy!
aquirium
Apr 23, 2013 06:17 PM
rojo_monl
Jun 14, 2012 08:06 PM
ICApproval
Jan 5, 2012 11:59 PM
jconway1980
Sep 12, 2010 08:13 AM
capt khaos
Dec 23, 2005 03:37 AM
