Replacing Throttle Body
Old Aug 8, 2015 | 10:08 AM
cukaracha's Avatar
Default Replacing Throttle Body
Hey guys,
The throttle body on my 2000 Si is binding and no amount of cleaning is getting it slinky smooth like it should be. I'm looking to buy a replacement TB, but it looks like the OEM part is discontinued.
What's a good aftermarket TB to get? I'd prefer to stick to stock bore since I don't plan to replace the intake manifold (and I read that the performance benefits are marginal at best), but I'd be open to a larger size in favor of price/availability.
Also, is the procedure for replacing the TB as simple as bolting on the replacement and transplanting the sensors over, and then letting the car run for a bit while the ECU re-learns the new system (at least that's what I've read, but kinda seems too easy...)?
Thanks!!
Old Aug 8, 2015 | 12:16 PM
Me, I'd go "bone yard" hunting first. You can use something like "car-part" dot com to help in your search.
Then, using an Accord in the same year range, with a bone yard find it would be a pretty simple change.
Just my opinion
Old Aug 8, 2015 | 12:43 PM
cukaracha's Avatar
Thanks for the reply!
The only issue is that the TB is specific to my trim (not the same on DX, LX, EX) based on the OEM part number, so that complicates things a bit.
I'm considering aftermarket mostly for price and availability. As long as it performs like stock (not interested in "performance gains"), I'll be satisfied.
Old Aug 8, 2015 | 02:25 PM
shipo's Avatar
Contrary to the claims of many aftermarket companies, there really are no performance gains to be had from replacing the throttle body.
Old Aug 8, 2015 | 03:42 PM
Car-part.com shows which Accords are donors to your model. Easy and inexpensive. Also check ebay for used TB options.
Old Aug 8, 2015 | 03:44 PM
cukaracha's Avatar
Yup! Hence the quotation marks
But more on the topic, is there a good brand I should go with? I'd like to avoid any fitment issues or quirkiness in idle rpm etc after the replacement.
Al_S
Jun 26, 2010 08:17 PM
myrtle71590
Jun 29, 2007 02:00 PM
accord4sroy
May 26, 2007 11:22 AM
mikel6690
May 9, 2007 02:45 PM
TedsF23accord
May 30, 2006 01:30 AM
