Reverse Gear Wiring?
I have installed a reverse camera and connected a wireless transmitter to it; however, the receiver needs a power source in the front of my car that is only active when in reverse. How can I access a power source that is only on during reverse, and is in the dashboard area. I have a Honda Accord Coupe EX-L 2004
Thanks
Thanks
The back-up (reverse) light is a green wire. One area to splice into would be at a 24-P white connector located next to the DLC/OBD-II port (under the left side of the dash). The green back-up wire is at terminal no. 23 of the 24-P connector.
If you take some pictures of the connectors right next to the DLC port and post them, I can probably add notes to the images you post.
The Data Link Connector (DLC) is the same as the 16P OBD-II port. Look under the driver's dash on the left side.
That port is used to attach a cable connector for an OBD-II scanner/reader or Honda's Diagnostic System (HDS).
Image 1 of diagnostic system:
http://imgur.com/aF97u1R
Image 2 of diagnostic system:
http://imgur.com/96WVFeN
I noticed a green wire, this?
http://imgur.com/hTKDqTp
You'll need to remove the under-dash cover to get a better view and gain access. See attached image for the area you'll be looking at.
After you remove the under-dash cover, take some clear pictures of the 24 pin White connector's wiring.
Refer to step number 3 that are part of this link to remove under-dash cover.
http://handa-accessories.com/accord/03-Security.pdf
