Rocker Arm Shafts (valve cover bolt)
Old Mar 28, 2008 | 09:19 PM
johnjokela
Default Rocker Arm Shafts (valve cover bolt)
hello, i went to replace the valve cover gasket on a 92 accord 2.2 , and snapped one of the bolts off that is also the rocker arm shaft for the valve cover bolt, is it ok to just pull the rocker arm shaft bolt and replace it with one from the junkyard and drop it in?without hurting anything,or taking everything apart,trying to do it without taking everything apart and readjusting the valves and torquing everything back, thanks for the info
Old Mar 29, 2008 | 09:17 AM
Default RE: Rocker Arm Shafts (valve cover bolt)
I would replace the bolt and torque to spec (16 ft-lbs for 8mm bolt which I think your's is). Loosening this one bolt should not cause a problem. There is another bolt a very short distance behind this bolt.
Technically, it is supposed to be torqued in sequence w/ the other valve train assy bolts (18 bolts!). In my view, you are likely to run into more problems w/ loosening the entire valve train and retorqueing than installing that single bolt and retorquing, but your call.
Old Mar 29, 2008 | 11:34 AM
johnjokela
thats exactly what i was thinking , got the bolts this morning,gonna replace the one and torque to spec, thanks for the reassurance,i appreciate it
Old Mar 30, 2008 | 09:11 PM
As long as you're in there, I'd check the valve lash.
RedLineZ_05
Dec 18, 2014 10:08 PM
troy331
Sep 22, 2007 06:50 PM
ArcticHonda
Apr 20, 2007 09:53 PM
MALSR
Feb 26, 2007 01:02 AM
91boz
Feb 2, 2007 11:48 PM
