Lower Rocker Arm Seals
Old Jan 31, 2007 | 08:28 PM
91boz's Avatar
Default Lower Rocker Arm Seals
Does anyone have the Honda part numbers for the 4 lower rocker arm seals? I have oil leaking into the spark plug tubes and need to get these replaced. My local Honda dealer showed me an exploded view of the head assy but I could not identify the seals. An exploded view with the part identified would do nicely. I already replaced the tube seals on the top but it is still leaking .
Old Jan 31, 2007 | 08:46 PM
RSM93HONDA's Avatar
Default RE: Lower Rocker Arm Seals
If u buy a valve cover gasket from the auto parts store it may contain the o-rings as mine did.
Old Jan 31, 2007 | 09:33 PM
They're #19. It's kinda funny how this picture shows them over on the right while the cam bearing caps are over on the left...
Old Jan 31, 2007 | 11:02 PM
ArcticHonda's Avatar
ORIGINAL: RSM93HONDA
These are upper seals only ^
Old Feb 1, 2007 | 01:55 AM
deserthonda's Avatar
they are # 19 as Jim says , you will need 4 of them part # 91301-pto-003
Old Feb 1, 2007 | 03:07 AM
When my daughter got a VC gasket set, it came with those seals. I think she got it at someplace like AutoZone, not the dealer.
So sometimes you DO get them.
Old Feb 1, 2007 | 12:16 PM
Good to know. FYI, I just bought 4 lower seals from the dealer for about $3 each.
Old Feb 2, 2007 | 09:02 PM
91boz's Avatar
Thanks for all the help guys. I will go to the dealer and pick up those seals.
Old Feb 2, 2007 | 11:48 PM
ORIGINAL: deserthonda
Desert, Buon Giorno..you Da Man with those part numbers...you must have your tech books there at your desk
Angelo
grizzleduser
Mar 12, 2011 06:01 PM
KYWildcat
Aug 17, 2009 05:24 PM
johnjokela
Mar 30, 2008 09:11 PM
ArcticHonda
Apr 20, 2007 09:53 PM
MALSR
Feb 26, 2007 01:02 AM
