Lower Rocker Arm Seals
Does anyone have the Honda part numbers for the 4 lower rocker arm seals? I have oil leaking into the spark plug tubes and need to get these replaced. My local Honda dealer showed me an exploded view of the head assy but I could not identify the seals. An exploded view with the part identified would do nicely. I already replaced the tube seals on the top but it is still leaking .
ORIGINAL: RSM93HONDA
If u buy a valve cover gasket from the auto parts store it may contain the o-rings as mine did.
So sometimes you DO get them.
ORIGINAL: deserthonda
they are # 19 as Jim says , you will need 4 of them part # 91301-pto-003
Angelo
grizzleduser
Mar 12, 2011 06:01 PM
