rotors
Old Jun 22, 2008 | 07:23 PM
snacks wy
Default rotors
I have a 2004 5 speed accord. I have had to turn the rotors twice in 55k miles. Is there an affordable aftermarket rotor that may hold up better. We drive a lot of highway miles and don't put any unecessary strain on the brakes regularly.
Old Jun 23, 2008 | 12:17 AM
Default RE: rotors
For some reason that seems about right for two sets of rotors..what do you other members get out of your rotors for the miles?
Old Jun 23, 2008 | 09:25 AM
Default RE: rotors
Bed-in the brakes next time.
Find somewhere you can do this without being stupid in traffic.
Brakereal, REAL HARD from about 50 to 10 mph - DO NOT STOP.
Drive around so they cool down for 5 or 10minutes.
Do it again about 6 times.
Warped rotors are usually not really warped. Brake pad material transfers to the rotors unevenly. Whats especially bad is holding the brakes at a red light when theyre real hot. After bedding them in like this, they seem to tolerate normal use much better.
Old Jun 24, 2008 | 02:11 PM
peter4jc's Avatar
Default RE: rotors
ORIGINAL: WheelBrokerAng
My '98, w/ 96K mi., still has the original front brakes, never touched the rotors or the pads. And when I put my summer wheels on last April they still looked to be ~1/8" or a bit more.
I'm convinced that a lot of rotor warpage has to do w/ unevenly torquing the lug nutswhen putting wheel on the car.
Old Jun 24, 2008 | 04:45 PM
poolman's Avatar
Default RE: rotors
Stay out of deep puddles with hot brakes also
Old Jun 26, 2008 | 09:46 PM
Alekat's Avatar
Default RE: rotors
Usually rotors never need to be re-surfaced --- unless they are mis-treated by poor braking habits or failure to replace the pads prior to metal to metal contactwith the rotor.
Believe it or not.
Old Jun 27, 2008 | 10:36 AM
falkore24's Avatar
Default RE: rotors
ORIGINAL: snacks wy
Brembo blanks. About $40 each. Way better than OEM.
Old Jun 27, 2008 | 04:30 PM
brayner's Avatar
Default RE: rotors
ORIGINAL: Alekat
Believe it or not.
is this true??
Old Jun 28, 2008 | 01:12 PM
Default RE: rotors
Not true for everyone, not for all the time. Depends on a lot of things.
Different pad material causesdifferent amount of wear to the rotors. And the biggest thing is driving habits.
benjiaccord
Mar 20, 2007 10:21 PM
deserthonda
May 12, 2006 04:06 AM
toicy4ya
Oct 23, 2005 10:50 PM
leetness_shows
Aug 14, 2005 11:14 PM
emaxxman
May 4, 2005 02:43 AM
