rough idle in Drive
Old Jul 31, 2010 | 04:52 PM
manu_b's Avatar
i tried what hondadude told me but there was not that much difference. after carefully analysing i saw that my vibrates only in D gear not in R and when i turn on Ac it doesnt start viberating until radiator fan kicks in and stops viberating when fan stops. Can you guys verify if the engine can be lifted a bit(littel less than quater of inch) with hand by holding passenger side mount cuz i can move mine thatmuch with hand.
________
Hydrocodone rehab forum
Old Aug 3, 2010 | 08:20 PM
manu_b's Avatar
guys here is big problem now, i changed my passenger side mount cuz it was blown. but after changing it voilet vibrations in steering wheel has stopped but now more annoying vibrations have started which are constant and i could hear vibrations in car can you tell me whats the problem now i am so much frustrated please help
________
Kitchen Measures
Old Aug 4, 2010 | 07:35 PM
After doing what HondaDude suggested, how about repeating the test with a MityVac on the front mount?
Old Aug 5, 2010 | 11:27 AM
manu_b's Avatar
thanx for suggentions everybody. problem is finaly solved. problem turned out to be broken passenger side mount and loose rear mount it turned 6 complete revolutions with hand before i had to use wrench. Little bit viberations left which i am pretty sure is due to front moun but could not find mityvac to test it also price of similar vacuum pump is almost equal to aftermarket front mount. I am posting some pictures of my broken mount and other stuff.
________
Ysr50
Attached Thumbnails rough idle in Drive-imag0064.jpg   rough idle in Drive-imag0063.jpg   rough idle in Drive-imag0065.jpg   rough idle in Drive-imag0067.jpg
Old Aug 17, 2010 | 02:11 PM
manu_b's Avatar
hi, srry to bother you guys again. i coudnt find mityvac as suggested by other members of forum. today i got my hands on vacuum guage and i checked the hose going to the mount by putting hose in one end of "t joint" and while putting my finger at one end, it gave reading of 21.5 in-hg ,but as soon as i put mount on the other end vacuum dropped to 6 in-hg. so does this mean my mount is leaking
________
LovelyWendie
Old Aug 17, 2010 | 05:03 PM
I never tested it that way, but yes it does sound like it's leaking.
Old Aug 18, 2010 | 09:25 PM
  #17
manu_b's Avatar
Default rough idle in drive[Solved]
Yes it was front mount, it was leaking from top. Thanks to everybody who helped me repair my car.
________
Marijuana vaporizers
Kpick
May 5, 2015 08:51 PM
bcd127
Mar 26, 2013 07:52 PM
HatchJunki
Mar 9, 2013 08:23 AM
Anse
Jun 24, 2009 12:02 PM
pmatos
Apr 12, 2009 01:04 AM
