rough running
my observation during driving tmy 96 accord it runs rough sluggish acceleration... any idea?
i replaced fuel filter, new plugs ( 2 months ago) new ignition coil, new oil change oil filter, air filteretc..
runs rough at idle?? if so,, you need to see if it is missing on 1 particular cylinder or across the board,, have you checked plug wires? no oil in plug wire tubes? did you use NGK ZFR5F-11 spark plugs ? is it a 4 or 6 cylinder ?
its a 4 cylinder accord, anyway problem solved i changed the plugs to NGK my bosch plugs super 4failed in just a span of a few months ( less than 6 months im sure and around 6 thousand kms run not miles)hmmm....
1.I was wondering what caused this premature failure with my bosh super 4 plugs?
2. And this kind of plugs good or safe for honda engines?
thanks!
thanks!
I have tried the platinum plus 4's from bosch in my nissan van, and i was very unhappy with them, didnt' have the problems you did thankfully lol. But my gas mileage went down by about 5 miles to the gallon and it didn't have any more power or anything they advertise etc.
I just stick with plain ole, single contact platinum plugs reasonably priced, long lasting, good spark.
bosch plugs are awful for hondas, they cause alot of other ignition compnent failures. I personally use Autolites although most on here think im nutty for it, but NGK's are the safest way to go.
vward24
Feb 15, 2007 09:47 PM
