Sponsored by:
Sponsored by:
RPM OF COLD ENGINE 4-CYL
Old 07-24-2008, 08:35 PM
z20
Default RPM OF COLD ENGINE 4-CYL
HELLO FOLKS,
IF YOUR IN EAST COST OR IN CANADA AND DRIVING A 4 CYLENDER, PLEASE TELL ME YOUR COLD ENGINE IDLE IN THE MORNING WITH TRANSMIS IS IN PARK, (AIR TEMP 18-21 DEGREE C).
FOLLOWING MY LAST POST WHICH WAS "UNINTENDED ACCELERATION" I HAVE NARROWED DOWN THE PROBLEM TO MAYBE HIGH COLD ENGINE RPM.
I HAVE NOT BEEN ABLE TO LOOK UP ANYWHERE THAT WHAT THE RPM SHOULD BE AT ROUND THAT TEMPRATUREWHEN ENGINE IS COLD.
MINE FIRST TIME IN THE MORNINGHOVERS AROUND 2000 RPM WHEN TRANS IS IN "p" AND ONCE I PUT THE TRANSMITION IN D CAR JUMPS FORWARD VERY QUICKLY AND IS VERY HARD TO CONTROL.
I WILL APPRECIATE EVERYBODY"S HELP.
Old 07-24-2008, 11:26 PM
Default RE: RPM OF COLD ENGINE 4-CYL
You dont need to SHOUT.
That RPM seems in the right neighborhood, but I'll have to start paying attention to it.
My present cars are manual trannys so control is never an issue.But all auto-tranny cars Ive everowned had braking power far exceeding the engine power, even at WOT.
It seems obvious to me that it is never safe to put an auto-tranny in gear without holding the brakes. And I mean HOLD the brakes, notjust barely enough to clear the brake-interlock switch.
I checked your other post, you said 2003. What trim level? California or 49-state car? If I try to look for that spec, I probably need to know exactly what it is.
Old 07-25-2008, 07:46 AM
z20
thanks JB.
the car is 2003 accord 4-cyl automatic EX , canadian version.
Old 07-28-2008, 07:59 AM
I couldnt find a spec, but since its under control of the ECU, it should turn on the check-engine light& set an error code if it was wrong.
hipramodbhu
01-11-2015 12:44 AM
d0n
12-10-2014 07:42 AM
bbqboyee
12-17-2013 01:42 PM
Nightrider
02-16-2007 07:08 PM
mrmatrix
08-12-2006 05:39 PM
Quick Reply: RPM OF COLD ENGINE 4-CYL
