RPMs
Old Apr 24, 2008 | 02:15 PM
RuffRyd's Avatar
Default RPMs
I have a 97 Honda Accord EX with about 165,xxx miles. When i step on the gas lightly, as it increases speed to about 40-45mph my rpms jump from 3 to about 3 1/2 & goes down to between 2-3. what can be causing this problem?
also, the gas pedal is a little tight, i have another 97 accord SE & the gas pedal ismuchlighterthan this one. Is there a way to fix this?
any help is appreciated
thanks in advance
Old Apr 24, 2008 | 03:01 PM
sir_nasty's Avatar
Default RE: RPMs
is this an auto or manual? can you hear the engine increase in RPM's with the guage? if so it sounds like a slipping tranny to me....
Old Apr 24, 2008 | 05:00 PM
RuffRyd's Avatar
Default RE: RPMs
ORIGINAL: sir_nasty
automatic, i will listen closely.
If the tranny is slipping, need to replace right?
Old Apr 24, 2008 | 07:10 PM
finch13's Avatar
Default RE: RPMs
ORIGINAL: RuffRyd
Replace or rebuild. At 165k, a tranny swap would probably cost what the value of the car is. Might be better to look for a new car, but that's worst case scenario.
Old Apr 25, 2008 | 04:33 PM
00AccordLX5spd's Avatar
Registered User
Default RE: RPMs
Is it a 4cyl or a V6?
Old Apr 25, 2008 | 05:05 PM
RuffRyd's Avatar
Default RE: RPMs
4 cylinder vtec.
Also when i replaced the stock radio (real pain in the .. to do) because of the cheap kit) my abs light came on, could it be that i probably hit somethin?
Old Apr 26, 2008 | 06:36 AM
Default RE: RPMs
Did you do wire splicing or fabricate an adapter harness between existing radio connector and new radio? If the former, you may have accidentially spliced into the wrong wire for power. That's why the adapters are a good idea.
Short blue, 2-wire service check connector under the glove box dash, turn keyswitch ON, and read ABS code from flashing ABS light. All short flashes-f, pauses-p (code 4-1 = ffff-p-f). If multiple codes, long pauses between codes.
Old Apr 28, 2008 | 10:55 AM
RuffRyd's Avatar
Default RE: RPMs
i bought one of those adapters & just matched the wire colors. 1 of the fuses got messed up & i replaced it but when i initially turned on the car to ck the stereo the ABS light had come on.
is that the only way to get the abs codes?
Old Apr 28, 2008 | 07:44 PM
Default RE: RPMs
Only way I know of.
Old May 2, 2008 | 01:11 PM
RuffRyd's Avatar
Default RE: RPMs
The weird thing i've been noticing is that i will only have that problem with the RPM's when cold, once its warm it ****fts much better.
I saw a Lucas transmission fix, has anybody tried it? will it work?
