Rpm's stops at 4,000????
Old Sep 24, 2007 | 05:27 PM
asher.fish
Default Rpm's stops at 4,000????
Sometimes like after driving for a long time....If i hit the gas it will speed up untill i hit 4,000 rpms. When it gets there thecar will shake untill i go under 4,000. Does anyone know how to fix this. Its on a 2002 honda accord 4 cylinder. Auto.
Old Sep 24, 2007 | 05:33 PM
sir_nasty's Avatar
Default RE: Rpm's stops at 4,000????
Do you have any check engine lights on? Does it drive normal besides that issue?
Old Sep 24, 2007 | 06:12 PM
asher.fish
yea both
Old Sep 24, 2007 | 06:49 PM
Take your car to autozone asap and have them read the codes that are stored on your ECU. They do this for free.
Post the code(s) on here. They are P####. I think that your car is going into limp mode as a precaution, and this can be caused by a number of problems. Once we know that code, then we can help you fix the problem.
Good Luck
Old Sep 25, 2007 | 12:31 PM
korrupt1's Avatar
Ill be watching this one closely as my car does the EXACT same thing....only as a 91 instead of a 02, but a identical problem, once CEL comes on I can't rev above 3500 if on the gas....annoying to say the least huh?
Old Sep 25, 2007 | 12:46 PM
Korrupt, You should short your service connector and count the flashes.
The 91 and 02 end up with the same result (ECU in limp mode), but may be caused by different problems.
Once you get your code, then start a new post, so we don't get confused.
Old Sep 25, 2007 | 08:01 PM
korrupt1's Avatar
no worries PAhonda! jjst keeping a eye on it....may go down and try short my connector tonight since I finally got some time
argarcia86
Mar 17, 2013 08:28 PM
argarcia86
Jun 24, 2012 12:14 PM
Mar 6, 2007 08:27 PM
xmx250
Oct 25, 2005 10:10 PM
mbliss
Dec 18, 2004 01:33 PM
