RSX replacement filter on an H22.
Old Jul 25, 2016 | 03:44 PM
H22Swagon's Avatar
Default RSX replacement filter on an H22.
Hello i placed the 2003 RSX fram replacement oil filter #7317 on my h22 in place of the large duffy filter offered from the catalog . I see the increase oil pressure logic from having a smaller filter. It mated fine to the sandwich and threaded fine.
Is this the right thing to do?
I do notice that my chipped gsr p72 starts sending signal at 4500 but the car engages vtec at around 4700. Thanks in advance
Old Jul 25, 2016 | 10:55 PM
What was your oil pressure before and after changing the filter?
Old Jul 26, 2016 | 07:16 PM
H22Swagon's Avatar
Not sure. I simply noticed that vtec 12v wire starts swnding at 4500 and i feel it engage at aroubd 4700. I dont have a meter on it. Im gonna introduce a oil psi gauge. The old head at my job goes "myth"! A B16 fanatic also hinted at the use of the smaller filter and for the past day i haven't had the guts to push the car to engage vtec.
Old Jul 27, 2016 | 11:23 AM
Does your H22 have IAB? Is the "event" at 4700rpm the IAB's opening up? That's not supposed to be at the same rpm as the vtec cam.
Old Jul 28, 2016 | 06:58 PM
H22Swagon's Avatar
Its a jdm h22a with november 91 p13 on the head/block it is equipped with the oem intake manifokd/iabs vacuum operated right? Is that the "blop" sound i mistake for a backfire the opening and closing sound when i play with the throttle from the engine bay? Im pretty sure the iabs works properly. When does s factory gsr computer engage vtec?
Old Jul 30, 2016 | 07:55 PM
H22Swagon's Avatar
Update my vtec solenoid switch was disconnected so vtec never engaged with the smaller filter. I now have normal sized mobile 1 filter on the car.
Old Jul 30, 2016 | 07:57 PM
H22Swagon's Avatar
Something tells me that
A) engines that take the smaller filter pump at a higher threshold and the internal bypass spring is set for those engibes.
An older Honda engine might be fighting with that pressure valve inside the filter.
B) results inconclusive : i was unable to see how vtec engaged with the smaller filter
Old Jul 30, 2016 | 08:01 PM
H22Swagon's Avatar
My theory is that the signature switchover point sound when vtec engages would be less noticeable because overall baseline oil pressure is higher from the get go and the distance from required psi for vtec ehagement is shorter. Anyone ponder these things?
Old Aug 1, 2016 | 11:32 AM
I don't remember what rpm each one engages. But from having a GSR for 10 years it's the IABs that make an audible change. The cam switchover happens at a lower rpm and that isn't a noticeable sound.
The IABs are actuated by vacuum & the VTEC cam is actuated by oil pressure. But they aren't passive - they are both commanded from the ECU. Higher or lower oil pressure doesn't change the rpm at which the cam switches. Higher or lower vacuum doesn't change the RPM for IAB switch either.
Honda_Dude
Jun 18, 2011 04:58 PM
09 BBP Coupe EX
Jan 5, 2009 09:24 AM
maxout
Aug 19, 2007 08:21 PM
stefanb21487
Jun 2, 2007 03:50 PM
Peperoni Nose
Oct 27, 2006 04:24 PM
