rubbing noise while in reverse
Old Jan 13, 2013 | 04:16 PM
zedjr's Avatar
Default rubbing noise while in reverse
I have a 92 accord m/t. Car makes rubbing noise while backing up. The noise is coming from left rear tire. It happens only while backing up. It is not a grinding noise. It is like a rubbing noise mixed in with the sound of chalk screeching across chalkboard in a way.
Old Jan 13, 2013 | 08:06 PM
go-part's Avatar
Former Sponsor
I would check the brakes on that tire, make sure the brakes fully release when you take your foot off the brake pedal. Also make sure the rotors aren't warped..
This truthfully sounds like the belts on your car are loose.. thats the noise they usually make
Old Jan 14, 2013 | 08:37 AM
I'll vote for the brake. Before it gets bad, they make strange sounds, & sounding in reverse only really fits with the brakes.
Old Jan 14, 2013 | 12:47 PM
zedjr's Avatar
What part of the brakes u think is doing this. The brake pads seems fine. Is the brake just not releasing properly when i take my foot off of brake. could that be it?
Old Jan 14, 2013 | 12:53 PM
Maybe not releasing? Sometimes the steel backing-plates of the brake pads is tight in the caliper bracket. So the caliper releases, but the pad is still rubbing.
The chalk-squeaking sound is a real good description of the little metal wear-indicator tabs rubbing against the rotor. Sometimes they start doing that when there's still 2mm of pad material remaining. You might have to take off the wheels & get a good look at the inboard pads.
Old Jan 14, 2013 | 01:25 PM
zedjr's Avatar
i thought maybe not releaSING CAUSE IT ONLY MAKES THESE SOUNDS AFTER I HAVE PULLED IN FORWARD AND PARKED AND THEN PUT IN REVERSE. it ONLY MAKES for a few feet. so if i keep driving in reverse it wont continue to make these sounds. Sorry for caps.
Inkyfingers
Sep 18, 2014 05:55 PM
elvis1977
Dec 3, 2012 08:08 PM
rjnyc
Feb 21, 2010 07:12 PM
joncnca
Aug 15, 2009 09:12 PM
FlyLow
May 8, 2006 06:00 AM
