rubbing/rasping noise when i drive??
Old Jan 25, 2010 | 05:48 PM
rjnyc's Avatar
Default rubbing/rasping noise when i drive??
First would like to thank those who helped me out with the front suspension, but now i am hearing a noise when i drive. Noise is like a rubbing/friction type noise (in the front of the car)like if i need to change my brakes but i changed my brakes and rotors 6 mo ago.
The noise can be slightly felt around the gas pedal not to mention if you put your hands on the inner steering wheel where the airbag would be u can feel it as well. My steering wheel does not shake though. What can this problem be?? I have been told two suggestions:
either the axle is messed up (although the boots are fine so i wouldnt see how this could be)
or the hub(wheel ball bearings)..any thoughts??
Old Jan 25, 2010 | 06:06 PM
kris_loehr's Avatar
Drive your Honda and as you change lanes notice if the noise changes which is the check for a wheel bearing noise.
Old Jan 25, 2010 | 06:25 PM
rjnyc's Avatar
i will try to hear if i notice but i know that the more i drive the less i hear it... In other words i really hear it in the morning when i first start to drive.. I hear it less the faster i go it seems..
Old Jan 25, 2010 | 06:35 PM
Noises can be difficult to diagnose over the web. Do you hear the noise when the car is stopped?
Can you figure out where the noise is coming from? Front/Rear Driver/Passenger side?
I would also add frozen calipers to the list that was suggested to you. Drastically uneven wear on the pads would point a stuck caliper.
Old Jan 29, 2010 | 07:33 PM
rjnyc's Avatar
sorry for the late response...yes noises are difficult to diagnose on the web..
Noise is definitely coming from the from and is more noticeable when i first drive the car. Sounds like a rubbing noise metal on metal type noise. Like i said i changed my brake pads and rotors.. I am hearing from people that it can be the ball bearings, or the axles...
Also i can sort of feel it on the gas pedal NOT the brake, and when i place my hands on the middle of the steer wheel while driving i can feel it as well, but my steering wheel is not shaking and the car is not moving one side or another when i let go of the wheel...
Any suggestions?? I know that an axle usually goes bad when the boot is torn, but can it even though the boot is not??
Old Jan 29, 2010 | 07:37 PM
What year/model is your car?
Old Feb 21, 2010 | 10:31 AM
rjnyc's Avatar
1998 honda accord lx
Old Feb 21, 2010 | 07:12 PM
Axle can go bad without a torn boot. It's just more likely that a torn boot causes the problem.
Get something stuck in between the brake rotor & the splash shield? Maybe bent the splash shield so it rubs against the rotor?
Inkyfingers
Sep 18, 2014 05:55 PM
zedjr
Jan 14, 2013 01:25 PM
elvis1977
Dec 3, 2012 08:08 PM
joncnca
Aug 15, 2009 09:12 PM
FlyLow
May 8, 2006 06:00 AM
