Seafoam When?
Hello to all.
I know I’m not posted to much but I’m always seeing the forum, this time I have a question regarding the use of seafoam engine cleaning, I already saw a lot of videos in youtube how to use it, but in not quite sure when to use it, I mean this must be performed before general maintenance? (Oil change) or can be used at any time?
The seafoam wont damage the engine? In the videos looks a lot of smoke, this is just for few miles?
Thanks to all for your support
Seafoam is just a petroleum distillate. It won't ruin anything, but I would not recommend leaving it in between oil changes. It changes the viscosity of the oil, though it doesn't necessarily break down the molecules themselves. The smoke is from it being added to the upper cylinders through a vacuum line, and burning off carbon and other gunk, you're supposed to high idle it (2500 RPM) for 2-5 minutes or so, the smoke stops eventually.
Regarding your question of "When", I would say never unless your car has been very poorly maintained, and even then I wouldn't recommend using Seafoam. Why? My personal opinion is that it is a waste of money and I've yet to see even a single verifiable instance where it helped anything.
Long story short, properly maintain your car, get your oil changes on time and use a high quality oil and the engine will far outlast the rest of the car.
Hello to all.
I just wanna say thanks for your support on this topic, now looks clear for me.
In the other side what oil is the most recommend, right know I’m using Liqui Moly 5W-40 and works very good for my point of view with ceratec additive in all oil changes.
In the other side the sea foam is recommended in the gas tank? Just to clean injectors? To be honest I want to avoid used with the oil as Kayway mentioned because will change the viscosity.
Thanks to all for the answers.
From my perspective, using Seafoam or any other product of that ilk when no problem is apparent is simply throwing money away. The fact is that modern fuel has all of the additives and detergents necessary to keep fuel injectors in tip-top shape for hundreds of thousands of miles. As for using Liqui Moly 5W-40, yikes, what year was your engine built? I cannot think of a single Honda motor built in the last twenty to twenty five years that needs such a heavy oil. Said another way, 0W-30 or 5W-50 for engines built up to about 2000 is the correct oil, and since then pretty much everything needs either 0W-20 or 5W-20.
Thanks for your support I'll keep in mind! But you are right now looks as you said is a waste of money.
In the other hand thanks for the tip for the oil
accord4sroy
Jul 30, 2007 01:28 PM
