Seat bolts torque specs
Old Sep 23, 2006 | 04:11 PM
Chiovnidca's Avatar
Default RE: Seat bolts torque specs
ORIGINAL: sir_nasty
if you look at the way that they are bolted in (the angle etc) you'll notice that under a collision incident it would pull on the bolt and have to snap the bolt before it would do anything, if they started to "rattle loose" you'd notice it... I believe that's why they aren't as concerned about it as you might think..
What if they're over torqued and that collision helps them snap off?
Old Sep 23, 2006 | 04:29 PM
sir_nasty's Avatar
I guess there is extreme's in every situation and I suppose that is a possibility but it'd have to be a pretty severe over tightening to torque them enough to allow/HELP them snap
Old Sep 23, 2006 | 09:43 PM
Chiovnidca's Avatar
ORIGINAL: sir_nasty
If you dont know how tight they should be....and some people dont. I never chastise anyone asking for a torque spec.
Old Sep 23, 2006 | 09:47 PM
Chiovnidca's Avatar
ORIGINAL: hondadude
Tighten until there is a sharp rise in torque and then 1/6 turn more. That is hondas rule for unspecified torque.
I came across another thread that got me thinking. How do you think that rule will work tightening an oil pressure sending unit?
Old Sep 24, 2006 | 08:57 PM
hondadude's Avatar
You can quit busting my chops on this deal anytime now!! It's in the honda training manual, you know the test you take when you work for the dealership. probably one of the first 5 tests you take. You don't remember that question from when YOU took the tests?
Old Sep 25, 2006 | 09:31 AM
Chiovnidca's Avatar
ORIGINAL: hondadude
No, I dont remember that, must be something new. What's a Honda training manual? Do you mean a Proformance test?
Old Sep 26, 2006 | 01:28 PM
  #17
hondadude's Avatar
26 years ago, when I started working on Hondas, they were called training modules, but then again I'm an experienced tech. Not some young buck trying to rut out a stomping ground like you are. Go bang your head with someone else for a while.
No wonder there are problems with good advice on websites, people like you can't stand to learn things, and try to run off knowledgeable people.
Old Sep 26, 2006 | 08:45 PM
  #18
Chiovnidca's Avatar
ORIGINAL: hondadude
I dont know what your problem is, i'm just asking you questions. If I see possible miss-information posted I speak up. BTW, we both started working on Hondas about the same time.
Old Sep 26, 2006 | 08:58 PM
  #19
deserthonda's Avatar
OK gentlemen don't you think it is about time to put a stop at this little quarrel before it gets any bigger ??
Personaly i have a lot of respect for both of you ( chio --hondadude) wether it is knowledge wise or helping members out.. and when noobies or junior members see that our senior member and 2 of the better techs in here bicker back and forth like this ...
it does not say a lot for the forum ..it might make some noobie run away
...I totally respect each person's opinion .. BUT
if one person wants to torque every sinlge bolts and nuts on the car so be it
if the other one does not feel that it is necessary so be it as well ...
But we cannot force our opinions on anyone else
so boys kiss and make up
Thank you...
JonJon13926
May 16, 2013 02:40 PM
Camryn
Jan 8, 2010 01:54 PM
redbull622
Sep 1, 2009 05:16 PM
theirlaw
May 8, 2009 01:14 PM
Pauls95
Apr 25, 2007 08:58 PM
