Shift issues - plus more
Old Dec 6, 2011 | 12:28 PM
Gwen's Avatar
Default Shift issues - plus more
Hello,
I woke up this morning and got into my car to go to work and noticed that I couldn't shift out of Park gear. I had to manually override the gear to get out of gear. When I did get out of gear I noticed the following as well:
Turn signals were out
speedometer is out
gasgauge is out
Powerwindows are out
What do you think is going on? Do you think I need to change the fuses?
Old Dec 7, 2011 | 05:29 PM
First, please post in the corect section, I moved this for you.
Check all of the fuses? Do the brake lights work?
Old Dec 8, 2011 | 08:54 AM
Gwen's Avatar
Sorry I put it in the wrong place.
Yes the break lights work fine.
Old Dec 8, 2011 | 10:18 AM
bigpat's Avatar
Almost A Senior Member
I think I read a similar post here a few months ago. I believe there is some sort of safety switch on the shifter mechanism that is linked to the brake light switch...Meant to only allow a shift out of park with the brake pedal depressed/brakelight switch on. As for the other issues, begin checking fuses and relays is my best suggestion. Is there a common relay for these problems ?
Old Dec 9, 2011 | 08:12 AM
Gwen's Avatar
I'm not sure. But I am going to look into to it. Thanks for narrowing it down and now I know what to look for. I will tell you how it turns out. Thanks so much for all of your assistance.
Old Dec 10, 2011 | 08:35 AM
What year is this? Most have a fuse that covers most of these, so yes there is a common fuse controlling several of the items not working,,,,,but again the year will help...should have asked that the first time as well
pace
Apr 17, 2008 04:40 PM
solobaric6800w
Jan 10, 2007 08:43 AM
YeuEmMaiMai
Oct 17, 2006 04:32 AM
thunder_x
Aug 18, 2006 02:48 AM
