shifter wont shift
Old Apr 26, 2011 | 12:30 AM
kalista's Avatar
Post shifter wont shift
i have a 94 honda accord lx and it wont shift.its stuck in park. the car starts fine. ive even put the key into the shift release lock keyhole and my car will run that way but when i shut off the car and put it back in to park.it will do the same thing stuck in park. i went to autozone and did and checked all the spots that they said would be the problem and it still wont do nothing
Old Apr 26, 2011 | 01:13 AM
Do your brake lights work properly?
You should download the 94 shop manual from one of the links in the online manuals thread in the DIY section. It will show you how to access the shift interlock solenoid. You can test the inputs for the electrical connector using a volt meter. There are 3 wires. The wht/grn wire should have 12V when you have the brake pedal pushed and the key in the II position. The grn/wht wire should have zero resistance to a good ground. There is also a couple of grounds that I would clean. G402 and G404.
Old Apr 26, 2011 | 07:40 AM
kalista's Avatar
thank you!!!yes the break light works and everything..i will check that out and see what happens.thanks again.
rydnlow1120
11
Nov 11, 2015 05:29 PM
Airhead
Jul 21, 2014 04:55 PM
bsd983
Mar 6, 2012 02:32 PM
thunder_x
Oct 24, 2007 10:26 AM
comptoncarl
Dec 5, 2006 08:37 PM
