should a vacuum hose or something be here?
Old Nov 8, 2009 | 08:16 PM
jtkj's Avatar
Question should a vacuum hose or something be here?
helping out friend w/ 92 accord LX by taking his car to get a new catalytic converter tomorrow because it's not passing emissions, and the shop told him the cat was the prob. Car doesn't have any of the symptoms I've experienced with bad cats, but what do I know.
Whilst replacing the coolant overflow hose for him I noticed a protrusion out of the valve cover that looks like it should have a vacuum hose or something, anything, attached. Does anyone know what this is??:
Pic is from the passenger side. Front of vehicle is to the right.
Many thanks!
Old Nov 8, 2009 | 09:57 PM
Its called the breather tube.
Its #4 below.
You can probably pick one up at a junkyard for little money.
Old Nov 9, 2009 | 06:46 AM
jtkj's Avatar
AWESOME - you rock AND roll
What does it connect to on the other end?
And - would this make the car fail emissions if it was missing?
THANK YOU THANK YOU!!!
Old Nov 9, 2009 | 10:39 AM
jtkj's Avatar
Talking
Found it!!
Thank you again PAHonda!
Old Nov 9, 2009 | 11:42 AM
If that thing is spewing oil into the intake (or into the engine compartment...) then check your PCV valve (#2 in PA's picture). Clogged PCV valve will send excess air out through that vent, carrying oil with it.
slidewinder
Aug 21, 2012 05:51 PM
Tek310
May 28, 2011 09:25 AM
skinnytexan
Oct 17, 2009 08:21 PM
Antarctica
Oct 29, 2008 12:53 AM
mak
Mar 29, 2008 08:11 PM
