is this sign of EVAP problem?
Old Nov 6, 2008 | 06:28 PM
ziya200
Default is this sign of EVAP problem?
Hi I drive a 2004 accord 4 cyln , I have noticed that while removing the cap from gas tank ( right after engine is turned off with 1/3 of the tank empty) I hear no "hissing" sound. this means there could be a problem with EVAP but I do not have any MIL on. Has anyone experienced similar situation before? thanks for your feed back.
Old Nov 6, 2008 | 07:27 PM
Default RE: is this sign of EVAP problem?
Verify that the check-engine lamp actually works. Look for the bulb-check for 2 seconds when you first turn the key ON.
If the CEL is OK, then you can trust the ECU to know the EVAP system is OK. An actual functional check of that sytem takes something like 8 pages in the shop manual.
stephen94accord
May 19, 2009 04:56 PM
Mid West
33
Oct 14, 2008 04:48 PM
beeline12000
Jan 4, 2008 02:05 AM
badxdawgx818
Sep 4, 2007 03:36 PM
RTexasF
Sep 8, 2005 09:06 PM
