what is the TELL TALE sign clutch is gone in 94 acc vtec
Old May 19, 2009 | 04:04 PM
stephen94accord's Avatar
Default what is the TELL TALE sign clutch is gone in 94 acc vtec
ok replaced slave and master AND FINALY GOT THE DAM CAR RUNNING!! (SWITCH PLUNGER BROKEN) clutch still seems to release high and slip a bit. Could this possibly be from not bleeding clutch very well or clutch adjustment?? need good news but im afraid thats not gonna happen is it. I think im gonna try and replace it myself EEEEEEEEEEEEEEEEEKKK!!! any pointers or good breakdown specs anyone?? have hynes manual but pictures are worth a thousand words. any help would be GREEEEAAAAATTTLLLYYYY appreciated.
Old May 19, 2009 | 04:31 PM
You should properly bleed the master/slave cylinder.
As for the adjustment, you can get all of this information from the Online Manuals thread in the DIY section. Spoon honda has a 94 shop manual that you can download.
Old May 19, 2009 | 04:56 PM
deserthonda's Avatar
air in system will not make clutch slip ,,, you might want to adjust the master cylinder rod and see if that helps,, if not , clutch is worn,,
TexasHonda
Jan 3, 2015 09:56 AM
wheresbrando
Apr 10, 2012 11:00 AM
stephen94accord
May 19, 2009 07:01 AM
maq1982
Dec 19, 2008 02:14 AM
powerpeecee
Jun 6, 2008 07:17 PM
