Size of the rear defroster fuse ?
Old Dec 7, 2016 | 05:25 PM
cyclops2's Avatar
Default Size of the rear defroster fuse ?
Anyone know what a 2007 accord V6 sedan uses ?
I am thinking of buying a rear defroster blower & heater unit. Upscale like the BMW. Used Might need to pull a separate # 14 wire for the current.
Anyone pulled a new wire to the trunk? Path taken ?
Thank you
Old Dec 9, 2016 | 05:48 PM
I could look it up but just guessing that the "set up" you are going for would be better suited to have its own fuse. There are several "add a fuse/fuse taps" out there and I would use one just to be sure.
A path along the drivers side "rail" would be best, there are already some wires running there. Pull the sill plates and lift the carpet and you will see them. Not sure where you need them to terminate but pulling the lower part of the rear seat is not that hard.
Jonah805
Sep 7, 2011 06:03 PM
expertrifleman238
Dec 18, 2009 07:04 AM
JetJock
Dec 1, 2008 08:42 PM
Antarctica
Oct 30, 2008 07:11 AM
Spatula
Nov 1, 2006 12:10 AM
