Static on radio when rear defroster enabled.
Old Oct 31, 2006 | 04:39 PM
Spatula
Default Static on radio when rear defroster enabled.
Here's the problem...I have a 2005 Accord EX (4cyc)...everytime time I have the redefroster on the radio goes static. I get horrible reception (read: no reception) until I disable it. Anyone else encounter this problem? The dealer told me there's nothing they can do.
Thoughts?
Old Oct 31, 2006 | 04:55 PM
sir_nasty's Avatar
Default RE: Static on radio when rear defroster enabled.
is your antenna built in to the rear windsheild? If so make sure that everything is intact, (the small lines that is) no breaks in them, you could try an external antenna too...
Old Oct 31, 2006 | 05:00 PM
Spatula
I'll have to check that out, that makes perfect sense!
Old Oct 31, 2006 | 05:18 PM
sir_nasty's Avatar
one other common culprit of radio issues is a bad engine ground.... I doubt it applies here but it is possible.... you could try installing a second ground strap on your motor
Old Oct 31, 2006 | 08:17 PM
Chiovnidca's Avatar
I've seen a few 03, 04 coupes do that. There's a control box behind the left c-pillar trim the defrost and antenae runs through. That's been teh problem.
Old Oct 31, 2006 | 09:28 PM
sir_nasty's Avatar
if that's the case then pulling that trim down and wrapping some sort of insulation around the antenna to protect it from the defrost should help.... perhaps even just wrapping it in some shrink wrap sheilding or electricians tape
Old Oct 31, 2006 | 09:30 PM
Chiovnidca's Avatar
ORIGINAL: sir_nasty
Needs a new control box, if that's the problem.
Old Nov 1, 2006 | 12:10 AM
YeuEmMaiMai's Avatar
replace the control box as suggested
CampyBob
Sep 30, 2017 09:38 AM
brownaddesign
Feb 1, 2013 07:17 PM
James C
Dec 19, 2011 04:44 PM
mailareers
Apr 22, 2011 08:42 AM
DVAZ05
Aug 30, 2007 05:45 PM
