slave cylinder fitting '98 accord
Old Feb 6, 2012 | 01:59 PM
cuberoach's Avatar
Default slave cylinder fitting '98 accord
Hello all, need help asap. I was replacing my slave cylinder and while I was hammering out the cotter pin for the fitting the whole unit itself broke apart including the fitting that goes into the slave cylinder. I have a new slave cylinder ready to go but now I cant seem to find a replacement fitting. The dealer seems to have the whole replacement hydraulic hose for approx $200. I just need that fitting. Has anyone had this issue? Might have to end up at a hydralic and fiitng shop...thanks
Old Feb 6, 2012 | 02:26 PM
What part number in the pic below did you break?
Old Feb 6, 2012 | 02:33 PM
cuberoach's Avatar
it should be where #15 o-ring hooks up to. from what i understand the whole hydraulic hose has to be ordered. I was told by the dealer that the connector fitting is not sold seperatly.
Old Feb 6, 2012 | 02:48 PM
cuberoach's Avatar
this is before it all broke apart. its the connector at the end of the line(silver). the connector easily unsrews off the line.
Old Feb 6, 2012 | 08:18 PM
That looks like the bleeder....to me...#6 in the pic from PA.
Old Feb 6, 2012 | 09:23 PM
cuberoach's Avatar
i realize that #6 is the bleeder valve.. thats not it. its the one next to it, that hooks up the clutch line. hopefully ill find one at the junkyard or get it made at a fitting shop
Old Feb 6, 2012 | 09:50 PM
g22cd5's Avatar
Supper Moderator
Go to summitracing.com/
Parts to order….
RUS-641431
AER-FBM2610
EAR-63010172ERL
ATM-2266
I think it's like $70 for all the parts cheaper than $200...Now this does eliminate your damper but I have never noticed the difference without one. This makes it where you have a line that goes from master to slave. No hard lines just braided SS line.
Old Jul 14, 2012 | 09:41 PM
Busareds's Avatar
sorry for gettin in on this thread a lil late, but I have a 01 EX that has a leak in the rubber section on the clutch line. Has anyone come up wit a fix of cutting out the rubber portion of the line and replacing with a braided???
Or if the parts shown in the above post from SummitRacing will work replacing the whole line on a 98-02 model????
Any help greatly appreciated before I have to by the complete OEM type of line and attempt to install.........
sparkleegrl
Jun 27, 2012 02:03 PM
Ken Boelter
Apr 13, 2010 09:55 PM
Buktheng
Jan 27, 2008 06:20 PM
gonecrazy
Oct 12, 2005 11:57 PM
gonecrazy
