Slight shudder in second gear
Old Apr 11, 2012 | 07:30 AM
Shuman47's Avatar
Default Slight shudder in second gear
Obviously I'm new here, but I have a quick question. I have an 04 coupe ex 4 cylinder, and i'm getting a slight shudder under second gear acceleration, mostly between 2500 and 3000 rpm. More apparent on turns, and most noticeable under moderate acceleration. both hard and very light acceleration seem to make it less noticeable. I'm going to check the grease in the CV axles, as well asmy wheel balance. Thanks for any input.
Old Apr 12, 2012 | 06:54 PM
Looks like you are on the right path, if the "feeling" is coming from the driveline I would suspect the inner cv joint(s) are going bad.
Old Apr 12, 2012 | 07:00 PM
I would agree with poorman on the CV joints, its seems like the most likely culprit. Especially since you said its more apparent during turns. Seem to be worse left vs right? If it is its usually the opposite side that is bad IE if its worse during left hand turns its probably the passenger side axle.
skipbroussard
Dec 7, 2013 08:01 PM
narcotix
Jan 12, 2013 07:56 PM
fl151
Sep 22, 2012 08:53 PM
wgtalbot
Jun 28, 2011 10:12 PM
