Small water leak left!
Old May 11, 2011 | 11:21 PM
SammyJ's Avatar
Question Small water leak left!
Over heating is now history. Replaced fan switch, thermostat, and radiator cap. Temp is very stable.
I am loosing 3-4 cups of water. No puddles, no hiss or steam, just wet area on the back side of the engine. Can't see where it comming from.
From what I see, it's hard to locate a pressure tester that fit's Honda.
Suggestions?
Old May 12, 2011 | 10:56 AM
Got ramps you can drive up onto? That way you can get a better look at the back side of the engine, from underneath.
There's a big steel tube running from the thermostat to the waterpump, across the back side of the engine. There's connections to a few smaller hoses, look there for leaks. Pressure tester would be best, because you can pressurize it cold (not sure where to suggest finding one).
Old May 12, 2011 | 11:18 AM
SammyJ's Avatar
Thanks,
I did not know about that tube!
Old May 12, 2011 | 11:54 AM
There are small coolant lines that run to Idle Air Control Valve and AICV (forget what it means) on the throttle body.
Also the heater hoses can also develop coolant leaks. They run behind the engine. Trace from firewall back to engine.
Old May 12, 2011 | 12:38 PM
IACV = idle air control valve
AICV = Saab/Bosch terminology for their version of the same thing. ("adaptive idle control valve") Since I'm on Saab boards too, I probably get em confused.
FITV = fast-idle thermo valve has small hoses too, but you don't have one of those in 1998.
Old May 12, 2011 | 08:25 PM
And a little coolant UV dye never hurts......I bet stores rent out UV lights as well, or sell them pretty cheap. They can then be used for other leak finding adventures.
Old May 12, 2011 | 09:20 PM
Hardware store might sell a UV light pretty cheap (blacklight).
Old Sep 20, 2012 | 02:48 PM
mikelac's Avatar
1992 Honda Accord
does anyone have a picture of the coolant lines that go in back of the engine, I'm trying to identify a leak, and I don't know where it's coming from?
Old Sep 20, 2012 | 06:03 PM
www dot hondaautomotiveparts dot com
click PARTS
put in your car's information
category = water pump/hoses
Unfortunately, there's also some water hoses scattered in other categories, like maybe throttlebody or heater.
skyfire322
Feb 28, 2013 08:50 PM
MysticBlueEX
Feb 20, 2012 09:06 PM
PinkFloridaFlamingos
Aug 23, 2011 10:17 AM
tlhfirelion
Oct 10, 2010 03:04 PM
natesriv
Oct 31, 2007 08:44 AM
