Small oil leak on my 94
Old Feb 28, 2013 | 02:23 PM
skyfire322's Avatar
Default Small oil leak on my 94
As I was underneath the car patching up the plastic covering, I noticed there was a very small oil leak near the oil pan/axle (front driver side). To give you a rough idea of the location, here are two pictures.
I have no idea where it's coming from either. Is there any "test" I can run to pinpoint where the location is?
Old Feb 28, 2013 | 08:50 PM
The oil has spread over such a big area so that your best way to pinpoint it is to clean it all up then watch for it to start leaking.
- oil pan gasket?
- lower timing cover? (might be crank or balance-shaft seal)
- seems too far forward to be coming from oil drain bolt, but ??
SammyJ
Sep 20, 2012 06:03 PM
MysticBlueEX
Feb 20, 2012 09:06 PM
PinkFloridaFlamingos
Aug 23, 2011 10:17 AM
tlhfirelion
Oct 10, 2010 03:04 PM
natesriv
Oct 31, 2007 08:44 AM
