soft beam !!!!
Old Dec 14, 2010 | 09:57 PM
f_15ss's Avatar
Default soft beam !!!!
Hi guys, how are you ....
iam from saudi arabia and i have accord sedan 08 and i want make soft beam like american accord model (see PICs)
VIN: jhmcp26398c423755
Old Dec 14, 2010 | 11:13 PM
I do not know how the headlight system is for the Accords in Saudi Arabia. Our 8th gen Accords do not come with High Intensity Discharge (HID) lights like in Saudi Arabia, etc. Our Acuras (U.S. Honda luxury brand) do come with HIDs.
Those are daytime running lights (DRL). The North American Accords uses the halogen high beams on a low brightness setting for DRL. If you are not already configured for that, I am not sure how easy it is to convert it.
The DRL system includes the driver’s multiplex integrated control unit (MICU), the passenger MICU, the left and right high beam headlights, and the DRL indicator. The DRL operates with the ignition switch ON (II), the headlights off (headlight switch OFF or in the parking position), and the parking brake released.
When the DRL are on, the MICU turns the high beam headlight control circuit on and off (duty cycle), which provides a reduced voltage (approximately 6-8 volts) to the high beam headlights (via the No. 1 and No. 28 fuses in the driver’s under-dash fuse/relay box and the No.1 fuse in the passenger’s under-dash ruse/relay box); the high beam headlights come on with reduced brightness.
Old Dec 15, 2010 | 01:25 AM
Thumbs up Hi Red Bull 1
Good solid information you've been giving out here in the forums..We'd like to Thank You for helping out your members..
Old Dec 15, 2010 | 02:16 PM
f_15ss's Avatar
thanx mr redbull-01 for answer me, but iam sorry idont anderstand for you
whatever i want photo my car, so you can see diffrant
hallstevenson
Aug 8, 2013 11:27 AM
thomask
Oct 26, 2008 11:21 AM
abhijitgp
Aug 23, 2007 06:32 PM
thunder_x
Aug 6, 2007 02:46 PM
