soft brake pedal
Old Jul 20, 2010 | 12:54 PM
gushaman's Avatar
Default soft brake pedal
94 accord 4 door 4 wheel disc abs
soft brake pedal sometimes. noticed a slightly damp area on the little cylinder in front of ABS module, thinking either this thing or master needs replacement. any ideas of how to confirm which one?
Old Jul 20, 2010 | 01:43 PM
MROOKIAN's Avatar
replace the master, and calipers. And if you want all new brakes replace rotors and pads. Expensive, but really easy.
Old Jul 20, 2010 | 01:50 PM
kris_loehr's Avatar
The master cylinder will leak down the brake booster it is bolted to when it leaks. To be sure if you have no signs of leaks there you could loosen the bolts just enough to pull the master away from the booster and see if brake fluid leaks down.
Old Jul 20, 2010 | 03:16 PM
gushaman's Avatar
the abs modulator accumulator has a noticeable wetness, does not look recent, i.e. it has dust and particulate imbedded in an area around the accum. could this be signs of a slow leak which would cause intermittant soft pedal issue?
96hondaaccord
Jul 29, 2014 05:22 PM
jtort92
Dec 2, 2012 11:43 PM
abhijitgp
Mar 20, 2011 08:26 PM
va125
Aug 31, 2010 05:19 PM
thomask
Oct 26, 2008 11:21 AM
