Soft Brake Pedal Sometimes?
Old Oct 25, 2008 | 11:23 AM
thomask's Avatar
Default Soft Brake Pedal Sometimes?
Hello All,
You guys were very heplfull last time with my ABS light and such,soI have high hopes of being directed right to the troublespot again. My issue is the car, a1995 Honda Accordruns well and gets great gas MPG, recently I noticed or shall I say felt, the brake pedal trying to escape my foot, once and awhile, although more often now. If I pump the pedal, the pedal comes right back up to the top. When I come up to a stop and apply the brake pedal, it starts to sink to the boards. I have checked fluid level andall good. No leaks on driveway or wheel cylinders can be seen so what can it be? Is it the booster ? perhaps a vacuum leak? Thanks in advance for your assistance.
Thomas
Old Oct 25, 2008 | 11:34 AM
Default RE: Soft Brake Pedal Sometimes?
The brake master cylinder likely has internal seals that are failing. The brake fluid bypasses the seal, and you get no pressure to your brakes. Replacing or rebuilding the master cylinder will fix the problem.
Old Oct 25, 2008 | 11:43 AM
thomask's Avatar
Great! is this a simple bolt on fix? or heavy duty work with brake bleeding etc.?
Old Oct 25, 2008 | 02:00 PM
finch13's Avatar
It's a fairly simple fix, but yes you will need to fully bleed the brakes. You might as well flush the brake system and put new fluid in while you're at it.
Old Oct 26, 2008 | 11:21 AM
thomask's Avatar
Thanks the pedal is now harder and stiffer than I was years ago!!!!
96hondaaccord
Jul 29, 2014 05:22 PM
jtort92
Dec 2, 2012 11:43 PM
abhijitgp
Mar 20, 2011 08:26 PM
va125
Aug 31, 2010 05:19 PM
gushaman
Jul 20, 2010 03:16 PM
