solution for erratic idleing
Old Jul 2, 2012 | 12:29 AM
my1st.honda93's Avatar
Post solution for erratic idleing
I've been having a problem with my idle fluctuating up then down during warm up,i've been told its my IAC valve FIT valve an so on,i was playn with "HER" like usual and i took the cover off the FIT valve and held my finger over the valve seat and noticed that the white cap holding the valve in place is a screw cap.
so i took a shot at tightening down the white cap that holds the valve in place,once it was tighten down i reversed a 1/4 turn then i replaced the cover and started "HER" up,when she started up i noticed the idle wasent fluctuating in fact the idle was to low,so i then turned my attention to the IAC valve,
on the IAC valve it has an adjustment screw(alen wrench type screw)so i adjusted it until i had normal idle!
I have had "HER" 4 months now and until now i havent heard "HER" sound so calm,as i was rubbing my head from hitting it on the hood being so surprised the way she sounds i also gave myself a pat on the back!
so i thought i would share this with all who have the same problem i "had"
"NOT NO MO"!!!
JohnInVa
May 4, 2011 03:39 PM
rjn721
Jul 8, 2010 05:31 PM
travelhondaman21
May 28, 2009 06:29 AM
Roadhead
Nov 13, 2006 10:49 AM
Markus26
Apr 17, 2006 10:30 PM
