Spare Tire for 1996 Accord 2 Door - Still Available?
Old Aug 9, 2011 | 08:28 PM
19962door's Avatar
Post Spare Tire for 1996 Accord 2 Door - Still Available?
Is the "donut" spare tire for the 1996 Accord still available? I was told spare tires are no longer available in such a small size.
Thanks,
Robert
Old Aug 9, 2011 | 09:55 PM
I don't know if you can get one from the dealership. If you enter the tire size on a site like tirerack.com, you may be able to find one. You would have to call and ask.
The other option is to pick one up from a junkyard.
Old Aug 10, 2011 | 11:29 AM
19962door's Avatar
Question Does An Original Spare Have To Be Replaced?
I had no idea this would be a problem. What size spares come with the newest Accords?
Actually, I have the original Goodyear donut spare. I've used it twice since 1996. I've tried to keep it inflated to the 60psi listed on the tire, although not always.
If you looked at the tire, it seems brand-new. Based on what I've read, I'm concerned about the issue of tire-rot.
Any suggestions would be appreciated.
Thanks,
Robert
Old Aug 10, 2011 | 12:56 PM
Forget that spare tire, it's rotted-that's more than likely why it wont hold air-nor will it hold up your car safely. Get a tire the same as what's on your other 4 wheels and by a OEM style rim from a salvage yard ..make sure you can bring it back if it fails a water test at your tire dealer.
Old Aug 10, 2011 | 01:06 PM
19962door's Avatar
Arrow Fitting Full Size Spare in Trunk Space
Forget that spare tire, uit's rotted-that's more than likely why it wont hold air-nor will it hold up your car safely. Get a tire the same as what's on your other 4 wheels and by a OEM style rim from a salvage yard ..make sure you can bring it back if it fails a water test at your tire dealer.
WheelBrokerAng:
The tire does hold air, i.e. it's never gone flat. The last time I checked, the donut was about 40psi. Should it stay at 60psi once I fill it?
Next question - is the full size tire going to fit into the space where the donut tire is?
Also, will I be able to secure the full size tire, same as the donut?
Robert
Old Aug 10, 2011 | 01:22 PM
Lightbulb
Hi:
measure your OEM tire from top to bottom and then measure your OEM spare tires over all height..if they're the same it should fit..Your OEM tire will be fatter, but it will be safer..tie it down any way you can..
Old Aug 10, 2011 | 01:40 PM
19962door's Avatar
Post Cost of Rim
Hi:
Ok, I'll do that, and report back.
Question - How much should a new rim cost vs. salvage yard rim?
Also, the spare only needs to be the same size as the other tires, not the same brand - am I correct here?
Robert
Old Aug 10, 2011 | 02:10 PM
If you got an aluminum rim, they are probably around 50 at the junkyard. The steel rims are less expensive.
I had a full-sized spare tire in my trunk. The tire diameter fits in the space. The tire did stick out of the top a bit, since the tire is wider. You can secure the tire using the bolt and metal hub holding your doughnut spare.
I think the spare tires are designed to last a long time and not dry rot. They aren't designed to be quiet, smooth, etc. You should also only use them for traveling a short distance.
You could get the pressure to 60 psi on the spare and see if the pressure holds at 60 after a week, month, etc..
Starps
Aug 6, 2021 06:22 PM
lesiza
Nov 2, 2013 12:05 AM
brjoro
Jul 22, 2009 07:24 AM
askingfornary
Jun 16, 2007 07:37 PM
thunder_x
Mar 22, 2007 11:38 PM
