Spare Tire Compartment: Water, Black Material
Old Nov 6, 2010 | 03:05 PM
rah140's Avatar
Default Spare Tire Compartment: Water, Black Material
Hi everyone,
I have a 2011 Honda Accord EX and a puddle formed in the spare tire compartment. I took it to the dealer and they do not know where it is coming from. Any ideas?
Also, When they were looking for the leak, they punched out one of the plugs in the tire compartment. I noticed that there was some broken apart black material left underneath the tire.
The picture is as follows:
Spare Tire Compartment: Water, Black Material-img_2294-edit.jpg
Does it need to be replaced and where can I buy this material?
________________________
2011 Honda Accord EX, 2.4L
Old Nov 6, 2010 | 03:55 PM
I am guessing that is sound deadening material. The car is under warranty, so the dealership replace that stuff.
Leaks are tricky to locate. Any seal on the trunk, rear window, taillight housing, plugged sunroof drain could be the culprit. Try to look for tears in any of the seals.
I would dry out the tire well. Put some newspaper in there. Put a garden hose on the lowest point (taillights) and see if the paper gets wet. Then work up to the trunk, rear window, then the roof to try to locate the leak.
Old Nov 6, 2010 | 05:03 PM
rah140's Avatar
if it was noise deadening material, then would it be applied to the entire surface?
Old Nov 6, 2010 | 05:10 PM
That is my guess, because it is does not look like it is covering any seams.
If that amount will decrease the noise to an acceptable level, then that is all the manufacturer cares about. Maybe it is cheaper to put it down as tape instead of spraying?
Old Nov 7, 2010 | 08:19 AM
All that does is change the mass of the panel so it doesn't vibrate at the same pitch. If they can get away with something a bit cheaper, they will.
Old Nov 7, 2010 | 03:06 PM
rah140's Avatar
ok, thank you for your help.
Old Nov 7, 2010 | 03:38 PM
rah140's Avatar
Are there any problems that can develop due to the water leak, such as electrical problems or premature rusting...etc?
Old Nov 7, 2010 | 05:37 PM
Mold or mildew can give you troubles.
You want to find out where the water is coming in. The car's under warranty, so the dealer SHOULD do that for you.
darkgreen18290
Oct 31, 2010 11:44 PM
and4rik
Apr 29, 2010 10:24 PM
brjoro
Jul 22, 2009 07:24 AM
askingfornary
Jun 16, 2007 07:37 PM
thunder_x
Mar 22, 2007 11:38 PM
