spark plug gapping inquiry
I lack experience in gapping spark plugs. The manual lists the spec for the spark plug gap for my vehicle/engine as .039 to .043. The new plugs I have are factory pre-gapped at .044. So I figured I'd try to gap the new spark plugs at .042 before installing. I took a flat-blade type feeler gauge I have (similar to this one: ) and because it of course does not include a blade with a thickness of .042, I held the .022 blade and the .020 blade together which seems to me should an acceptable method of measuring/matching a gap of .042. But I am finding that when I hold those two blades together as described that they do not seem to fit within the .044 factory gap of any of the set of my four new spark plugs (blades just slightly too wide to fit the gap). With my wire-type gauge, this type
the two closest wire measurements to my desired gap of .042 is .040 and .045. When I try to fit the .045 wire gauge into the factory gap of all my new plugs, it indeed will not fit (wire too wide), and when tried with the .040 wire indeed slips easily into the gap with room to spare. My question is what is an acceptable/proper method for me to get these new plugs gapped to .042 and be confident about the accuracy of that gap. Any comments appreciated.
Just me but I'd call it "good to go"...you are less than .45 and more than .40. Also note with the "fancy" plugs - plat or irid - you have to be careful not to "bend/push" on the center part.
I've always used NGK plugs in my Honda's. I check the gap before install but I have to say I can't think of a time I had to adjust them.....again just me. |
(Post 352994)
Just me but I'd call it "good to go"...you are less than .45 and more than .40. Also note with the "fancy" plugs - plat or irid - you have to be careful not to "bend/push" on the center part. I've always used NGK plugs in my Honda's. I check the gap before install but I have to say I can't think of a time I had to adjust them.....again just me.
I didn't bother getting the fancy plugs, mine are the more standard type; specifically I'm gonna use the NGK brand of their "V-Power" spark plugs (number ZFR5F-11). Thanks poorman212. BTW still struggling with the "BD project". Hit a snafu because when I tried to reinstall my coolant block plug I discovered it wouldn't screw back in because a couple of those fine threads on the the plug got buggered up somehow. Ordered a new plug and it'll probably be here in a few days and I might get lucky and be able to get it screwed it into the hole where it belongs under there where the sun don't shine. And it'll be extra fun because it's freezing a** cold here now outside in my "workshop" (driveway). Meanwhile, if the plug doesn't get here first, I might to ahead next and at least install my new spark plugs as I look ahead to someday in the very near future (I hope) when I get that block plug reinstalled and can continue as planned pre-snafu. |
With the NGK's you got you should be fine....I was remembering a pic of your old plugs that were either irid or plat NGK plugs.
Wish I had advice on the drain plug but I've never messed with it/them on mine. I've posted before about cold....I think we are getting to all of 45 or so today. Which means I can't hardly go outside yet have projects that need attention.....noticed a "tick" on the Pilot - valves need adjusting. Suspension on the old Ford needs replacing, I had forgotten about the old I-beam suspension on those until I got under there. |
1 Attachment(s)
With the NGK's you got you should be fine....I was remembering a pic of your old plugs that were either irid or plat NGK plugs. https://www.hondaaccordforum.com/for...ine=1416074218[/URL] Wish I had advice on the drain plug but I've never messed with it/them on mine. I've posted before about cold....I think we are getting to all of 45 or so today. Which means I can't hardly go outside yet have projects that need attention.....noticed a "tick" on the Pilot - valves need adjusting. Suspension on the old Ford needs replacing, I had forgotten about the old I-beam suspension on those until I got under there. You better get out there and get busy on them Pilot valves and that there Ford suspension; probably ain't gonna get much warmer for ya until spring. ;) |
Originally Posted by sgull
(Post 353011)
As I said I wish I had some "trick" or something to help with the drain....all I can do is wish you luck. |
An extra .001 isn't going to matter. I know I don't have the ability to measure that close. The spark will have no problem jumping that gap.
P.S. I exceeded my Corvair picture showed up! It looks better when it's a big picture, even better in person. |
the sad thing is with the cold I might just pay someone to do the valves....with the cold and me getting older it is a hard decision. I wish I had some "trick" or something to help with the drain....all I can do is wish you luck. |
Originally Posted by Corvair
(Post 353047)
I recently replaced my plugs as well, my old ones were iridium( must have been on sale) I used the factory recommended NGK spark plugs gapped at .045,,,spec is .044,,, It runs great, last set of plugs have been in there for at least 5 yrs, good luck on the drain plug. Keep us informed on your progress.
