Speedo not working
I HAD a D4 flashing light and a check engine light and speedo not working , so I researched and a common problem was the VSS. I replaced it with an Ebay one. It was not hard, just very hard to get to. Now the D4 is not flashing anymore and the check engine light is off, but the speedo is not working still.
I have read about a speedo head but not sure what it is.
What should I do next besides check codes because I can never do that right?
Forgot to mention that right after I got the coupe the d4 started flashing and the speedometer and odometer stopped working.
Now no flashing lights but the speedo and odometer don't work. Grease under my nails, a back ache from bending over and its still not fixed.. grrrr..
Are you sure you inserted the tiny link between the VSS and the axle drive gear? If you lost this when removing old VSS and failed to insert a new one, this would account for no speedometer movement.
Have you noticed whether the odometer is working? If yes, the VSS signal is being transmitted, but speedometer circuit or movement is damaged. You will either have to pull and replace the instrument panel, or send your panel off to be repaired. Check www for sources of this service and check for posts on same subject.
If odometer is not working either, then you may not be getting a VSS signal to the instrument panel. Check wiring (org) and all connectors.
http://techauto.te.funpic.org
on the upper left side under REPAIR GUIDE you will see VSS click on it .. Hope this helps ..
Also if you look at the pictures under VSS REMOVAL ,, Texas is talking about the little drive link to make sure that you reinstalled it
next time you do some work on your car you might want to wear a pair of those thin latex gloves....No grease under finger nails :-)
When the speedometer stops working, try to use the cruise control. If the cruise control works, then the VSS is sending out the right signal.
Does the speedometer needle go to ~19 mph when its not working?
