Speedometer Off by 15 MPH
Old Mar 29, 2010 | 12:34 AM
legionofone's Avatar
Default Speedometer Off by 15 MPH
Hi guys, my girlfriend just got a 94 accord auto for free and it has some issues. I have fixed most of the issues, leaking radiator, brake lights always on, radiator fan always on.
The one issue I was wondering about was the speedometer was off by 15, anyone know what could be wrong or how to calibrate the gauge cluster?
the previous owner replaced the transmission (dont know what year it was from)
wheels and tires are stock size.
Old Mar 29, 2010 | 07:00 AM
Any evidence the cluster was dismantled? It's pretty common to have similar damage to the gauges after installing glowing-backlight stuff over the gauges. Or if the prior owner ever removed the needle or ???
Old Mar 29, 2010 | 04:45 PM
just seems to be off, the previous owner said it happened when she changed the transmission... could the transmission be from a different car h22/f23 and not work right?
Old Mar 29, 2010 | 04:56 PM
I don't know how to tell whether the pulse frequency from the VSS is supposed to be different for those different cars. But that's not something that's a common complaint while lots of people have swapped transmissions without mentioning that problem.
Wrong pulses from VSS wouldn't be a CONSTANT offset. It would be a percentage change. For example if it's off by 15 when you're driving 60, then it would be off by 7 when you're driving 30.
A constant offset would result from removing the speedometer needle then putting it back on wrong.
Old Mar 29, 2010 | 07:04 PM
found out how to calibrate the speedo
Old Mar 29, 2010 | 07:46 PM
How do you calibrate it?
foxracing31702
Nov 8, 2007 04:47 PM
bww
Aug 14, 2007 05:56 PM
Antarctica
Jul 2, 2007 10:40 AM
chibiko
Mar 19, 2007 04:03 PM
balance55113
Dec 19, 2006 08:53 PM
