Speedometer Problems Again!
Old Oct 26, 2007 | 01:19 PM
91boz's Avatar
Default Speedometer Problems Again!
I am having the same problem with the speedometer needle getting stuck around 10 mph and not regestering the correct speed. I replaced the cluster assembly earlier this year with a used unit from Ebay and I am now having the same problem.Both the odometer and the cruise control works so this points to the speedometer as the fault, correct? Being an electronic tech I understand that the VSS sends out pulses to the unitand with so many units going bad there must be a common fault. Anyone had success repairing their speedo?
Old Oct 26, 2007 | 01:24 PM
sir_nasty's Avatar
Default RE: Speedometer Problems Again!
speedo's are built to be tamper proof/resitant so I doubt you can repair it. this sounds odd but try reseting your trip odometer and see if that helps. and yes it sounds like a speedometer issue to me. I'd probably just buy one with a warranty or buy OEM honda and depending on what year your car is it may be a common issue
Old Oct 26, 2007 | 03:53 PM
My speedo would get stuck at 20mph, and the odometer and tripometer would not work.
All other gauges worked fine. I sent my speedometer off to a speedometer repair shop (google search for one), and they repaired it. It cost around $120 and the speedometer has been fine ever since then.
First90AccordMan
Feb 9, 2012 05:33 PM
bigb609
Dec 27, 2011 07:18 PM
abhijitgp
Oct 4, 2008 11:32 AM
Jul 24, 2006 03:55 AM
Jun 2, 2006 02:24 AM
