Spindle Nut Size
Old May 10, 2013 | 04:01 PM
RobinsonRicer's Avatar
Question Spindle Nut Size
Im looking around online and in the manual and I see different size spindle nuts. I gotta get one to change my rotors. I see 24mm in the FSM and 31mm on certain sites selling the sockets and then on forums I see 36mm. Whats the size for my 97 accord?
Thanks
Old May 10, 2013 | 06:20 PM
Jethead102's Avatar
32mm for the rear on my 02 accord, which should be the same on yours. Do you really have to remove that nut to access the rotor?
Old May 10, 2013 | 06:27 PM
Theyre captive rotors on the front. I need to remove the lower ball joint and tie rod, flip it around and unbolt the hub to get the rotor out. Its a fun job :P
Old May 10, 2013 | 07:14 PM
Roader's Avatar
As I recall the front is 36mm, or 1-7/16". My local Advance Auto Parts loans them out.
24mm is probably the fastener diameter.
Old May 12, 2013 | 11:05 AM
Ok thanks. The FSM says spindle nut: 24x1.5mm. I know the 5th gens have a slightly different wheel/suspension make up than the 6th gens. Ill buy both sizes and see which one works.
Old May 12, 2013 | 02:42 PM
You also have to remember that "24x1.5mm" is the thread size. Then somewhere else, 36mm is the wrench size.
Sorry, for 1997 I don't actually know the answer to your question. My newer Hondas use 36mm wrench on the front axle nut, but I don't know what other years that covers.
Old May 12, 2013 | 04:51 PM
Oh thats true. I checked at Advance. The guy compared it with the actual part. It was 36mm.
JonJon13926
Jul 13, 2013 11:51 AM
RobinsonRicer
May 9, 2013 01:26 PM
brandon0409
Mar 9, 2012 06:22 AM
drummer1279
May 29, 2008 08:56 AM
Hop
May 18, 2007 12:47 AM
