Splashed Paint
Old Nov 7, 2006 | 02:56 PM
Daveyjones's Avatar
Default Splashed Paint
Drove thru, of all things, a puddle containing paint....
The front wheel well is splashed with it, I dont think there is much I can do about that but
that black trim below the drivers side door has a good bit of it. I also got some on the door but was able to remove that.
I tried turpentine to remove it but not much luck, not sure what that black trim material is..
Also have some paint on the rear tire...
Any suggestions? I was thinking of just buying a spray black paint to cover it...
BUt I'd rather ask you people FIRST.
Old Nov 7, 2006 | 04:16 PM
sir_nasty's Avatar
Default RE: Splashed Paint
you could try treating it like road tar and spray some wd-40 on there and lit it sit for a minute, then scrape at it with your thumb nail.... depends on what type of paint it is I guess...
Old Nov 7, 2006 | 09:06 PM
Daveyjones's Avatar
Pretty sure its oil based paint.....Ill try that wd 40 maybe even gasoline
Old Nov 10, 2006 | 02:41 AM
lightshow's Avatar
rubbing compound
Old Nov 10, 2006 | 03:22 PM
Daveyjones's Avatar
Rubbing Compound.....
GOOD ONE...lemme try that....
MW242
Jul 10, 2013 05:54 PM
andrew.james
Oct 27, 2009 04:07 PM
AyashiFX55
Jan 31, 2008 06:54 PM
WATCHER
Sep 1, 2005 10:56 AM
WATCHER
Oct 17, 2004 05:12 PM
