Spool valve leak
Old Feb 12, 2020 | 06:03 PM
Jonathan Valencia's Avatar
Default Spool valve leak
Hey guys,
i have a dilemma. I have a spool valve assembly I had leaking. I bought gaskets on amazon that I had issues with, so I opted to get a new Honda assembly and use the gaskets from that unit. In installing it, I overtorqued the rear nut. I drilled it out with some help, and got the part on. In the city, and at idle, I have no leak, but at highway speeds, I am leaking. Two of the three bolts are snug and won’t tighten without force, the other though that is pictured moves easier. Could it be I got oil where it was? I made a mess when I initially over torqued the nut. I want to tighten it to stop the leaking, but am afraid to over torque. Any suggestions?
Old Feb 13, 2020 | 03:37 AM
Did you intend to attach a picture? There is not attachment on this post.
Old Feb 13, 2020 | 03:55 AM
Seanjordan20's Avatar
No pic, but your torque should be 8.7lb or 12nM. If you don't have a torque wrench use an 1/4 wrench and snug the bolt then 1/4 turn. I don't like giving those instructions because snug can mean different things to other people.
Old Feb 13, 2020 | 04:20 AM
my apologies. I will update it.
Old Feb 13, 2020 | 04:21 AM
the thing is, I am afraid to continue turning the one bolt. It seems to have slack, and I’m afraid to over torque it again. I’m gonna raise it out, clean the site for the bolt, then snug it up. I’ll be careful
Old Feb 13, 2020 | 02:06 PM
The Toecutter's Avatar
Were you able to all of the remains of the snapped bolt out? Or did you have drill it out and re-tap it? Just asking, as you might want to think about adding a helicoil to that hole so you can torque it to the proper spec.
Old Feb 13, 2020 | 02:11 PM
the bolt I over torqued was removed and the new bolt is actually in the spool valve snug. It’s a different bolt hole. I think I will need a helicoil. Is that difficult?
Old Feb 13, 2020 | 02:15 PM
It's not hard, but it requires the correct size drill bit, and tap for the helicoil, along with the helicoil install tool.
Old Feb 13, 2020 | 09:04 PM
Drill, tap, & tool come with the HeliCoil "kit". Don't buy the "refill" because that only has extra coils.
Old Feb 14, 2020 | 03:08 PM
Good point. Some of the better kits include the drill bit and tap along with the tool. A friend of mine bought such a kit last year at a garage sale. Very nice little kit.
Jonathan Valencia
Feb 11, 2026 01:54 PM
eddiel_torres
Sep 2, 2019 12:12 PM
corey246
Jun 8, 2012 08:12 PM
rah140
Apr 8, 2012 04:13 PM
mbogosia
May 27, 2008 09:24 AM
