1991 Accord Oil Leak
Old May 26, 2008 | 05:15 PM
mbogosia
Default 1991 Accord Oil Leak
Hey guys, I have an oil leak in my 91 Accord sedan. The pictures below show the leak which is right near my passenger side wheel on the side of the engine. Let me know if anyone has seen a leak like this before and could help point me in the right direction. I noticed the black cover in the picture. It seems like the leak is coming from under it or above it. I didn't want to take it off until I knew what it was.
Old May 26, 2008 | 05:38 PM
Default RE: 1991 Accord Oil Leak
I would clean the engine with degreaser to remove most of the oil. Finding the highest point on the engine should pinpoint your oil leak.
On the pass. side, the distributor o-ring leaking oil is a common problem. Try to feel under the distributor for oil. Also the valve cover gasket is another possibiltiy for an oil leak.
Old May 26, 2008 | 05:51 PM
mbogosia
Well, I did notice the distributor leaking and replaced that o-ring already. I thought that would fix everything but there is still another spot leaking somewhere below the battery near the wheel well. I need to really get into it and take a look. It is a pretty tight squeeze on that side.
Old May 26, 2008 | 06:11 PM
eric123's Avatar
It could be the transmission leaking. I would clean it all off and try to pinpoint it.
Old May 26, 2008 | 06:23 PM
mbogosia
I thought about the transmission, but the oil doesn't have a red tint to it.
Old May 27, 2008 | 09:24 AM
drummer1279's Avatar
with all the grime and such that collects near that area being so close to the road, it could very well be tranny fluid and you not notice the red tint.
CB7-SE-1991
Jan 29, 2013 04:45 PM
alltime3rdwheel
Dec 31, 2012 10:46 AM
frost506
Jan 16, 2012 07:21 PM
mamtsberg
May 30, 2010 07:04 AM
Accord91Pearl
Aug 14, 2008 06:56 PM
