squeaky belts in 90 accord
Old Mar 4, 2008 | 10:16 AM
SilverCityAccord's Avatar
Default squeaky belts in 90 accord
on start up, my belts will squeak for 2 or 3 seconds, just kind of annoying. then other times it will sound like a ****in box of bottle rockets were thrown in a fire pit lol. will replacing the belts solve my problem? not realy a mechanic but just figuered id ask. thnks
Old Mar 4, 2008 | 12:03 PM
finch13's Avatar
Default RE: squeaky belts in 90 accord
1. Change your language. I know it sucks and I curse like a sailor, but it's forum rules and it's makes for much better reading.
2. Search. Squeeking belts has been cover 128041243 x 10^22374 times.
3. Replace the belts. If you have a 12mm and 14mm socket, maybe an exentsion, 20 mins and $40you'll be good as new. Tension the belts so there is about 1/2" of flex on the longest part of the belt.
Old Mar 4, 2008 | 02:46 PM
hondadude's Avatar
There is a 14mm pivot bolt at the top of the alt [not in the pic]
then a 12mm at the bottom, loosen them up;
Then there is a long threaded bolt 10mmto increase the tension.
I usually make that ALTbelt "Banjo String" tight
[IMG]local://upfiles/5417/37CD7F8228AF4E15BA05B804F6FF570C.jpg[/IMG]
eazycash
Jun 4, 2012 07:59 PM
aborbonio
Feb 25, 2011 09:11 PM
mugenpaolo
Apr 13, 2009 09:34 PM
bds34
Sep 5, 2008 11:09 PM
hongu
Jun 8, 2005 09:38 AM
