Squealing Problem!!
Old Aug 16, 2011 | 10:44 AM
immortal's Avatar
Default Squealing Problem!!
Hi, I have a 2002 Honda Accord 2.3 Type V UK car and have an annoying squealing problem.
Whenever I put the blowers on I get a squealing noise.. It sounds like a fan belt slipping. It does it more when I put the Aircon on but also does it when the Aircon is off. I've removed the power to the compressor so the Aircon doesn't work now and it still does it.
The belts are new and they are tight enough.
Any ideas??
Old Aug 16, 2011 | 11:54 AM
What about a squealing bearing in the actual blower motor (under the dashboard)? I think you can get to that from the footwell (with some contortion).
Our USA Accord is a different car vs your Swindon-built car, so my parts drawing might not be very useful. But here goes...
The blower #5 fits into the bottom of the round ductwork. You probably have to remove a trim panel or 3.
Old Aug 17, 2011 | 03:45 AM
immortal's Avatar
Hi, thanks for the reply. It's definitely coming from the engine bay. After researching on google, I've found another chap who had the same problem and he had replaced everything , including Aircon compressor, alternator, belts etc and it turned out to be the crankshaft pulley so I'm going to try that I think
Matt
Old Aug 19, 2011 | 11:38 AM
Crank pulley would be a fairly big job. Before you replace that, try to pinpoint the location of the sound. What if it's just the belt itself getting old & hardened.
Try a scrap piece of garden hose as a poor-man's stethoscope.
jill hughes
Apr 3, 2011 08:34 PM
sall
Sep 5, 2007 11:38 AM
forcefx
Aug 21, 2007 10:40 PM
paul_doors
Dec 1, 2006 02:09 PM
bill3_us
Sep 19, 2006 04:37 AM
