srs light
Old Nov 14, 2012 | 10:39 AM
tobybul's Avatar
Default SRS Light Reset
My SRS lite started turning on/off and now its just on. Now the side airbag lite comes on once in a while by is off most of the time. Has this happened to anyone? Help in diagnosing please?
Old Nov 14, 2012 | 06:00 PM
Which one of the Accord's is this on?
Old Nov 14, 2012 | 08:27 PM
tobybul's Avatar
2000 ex
Old Nov 14, 2012 | 08:40 PM
I'd check for srs codes, the dealer might be on the hook for this one. I'll guess/bet that the drivers seat belt buckle is bad. Some have cleaned theirs and been fine....others have been able to get the dealership to cover it under warranty.
Old Nov 14, 2012 | 08:50 PM
tobybul's Avatar
thanks. let me chk the buckle first.
Old Mar 20, 2013 | 01:50 PM
tobybul's Avatar
The only thing the dealer did for me is fix one of the rear seat belts that is stuck in the tucked in position.
They said Honda does not cover anything electronic related even with the SRS. So my SRS light is still on.
Old Mar 20, 2013 | 02:43 PM
tobybul's Avatar
I found the procedure to reset the SRS light. So I'm following the steps and my problem is I can't seem to unplug the yellow connector. I think there is something that needs to be squeezed for it to come off but I can't figure it out.
I don't want to force it for fear of breaking something. Any help please?
Thanks.
Old Mar 22, 2013 | 11:34 AM
Did you figure it out?
Some of the srs connectors have a "spring lock" type connection....not sure if that connector is one or not. If it does, there is a "sleeve" that has to be pulled back and then the connector will come out.
OneEyed
Jun 25, 2015 05:32 AM
brayner
Feb 12, 2013 06:59 PM
01AccordLX
Apr 4, 2012 01:39 PM
01hondaccordlx
May 18, 2005 11:51 PM
bj70alex
Nov 22, 2004 01:56 PM
