SRS Partial reset
Old Mar 21, 2011 | 09:31 AM
HondaPerson's Avatar
Unhappy SRS Partial reset
Hi,
I have just bought a 1995 Honda Accord Wagon. I realized after I got the car that the SRS light is on all the time. On the next day I got laid off from work and cant afford to take it to the dealer. The methods that are shown in Youtube and this forum helped me find the location of the MES connector and try reset the SRS light. I used a paper clip and put it into the MES connector (yellow with grey wires) and turned on the ignition. The SRS light went off in 6 seconds and then I removed the paper clip. The SRS light came back on. I put the paper clip back in less then 4 seconds. The SRS light remained light. What should I do how can I find the source of the problem. I have a lot of background in repairing electrical and automotive devices. Please give me a detailed info. I would really appreciate it. Thank you in advance.
HondaPerson
Old Mar 22, 2011 | 03:29 PM
BillsWagon's Avatar
Default Progress?...Question
Hi, Have the same problem on a 1991 wagon but in addition neither the horn nor the cruise set switches work. Got any ideas? Thx, Bill
Old Mar 23, 2011 | 08:06 AM
Old Honda Dude's Avatar
Default It's complicated
Usually the problem is with the steering wheel spool cable. If you have a consistent problem with your srs system the light will come back on. It's a pain to re-set those error codes. congrats on patients. I will look at this later. I have to go.
Old Mar 26, 2011 | 05:46 PM
Hi,
I managed to get the code from the SRS light. The method I used is to jumber the Blue connector under the glovebox and start the car. Yes, I said start the car. I does not do any thing until I start the car. I got a code that looks like 5 long blinks and 1 short one.
After that, I turned the engine off, took the key out, took the jumper out of the blue connector, and waited more than 10 seconds. I went to the drivers side and put the jumper on the yellow MES connector and turned the ignition on to the II position. The SRS light came on for about 6 seconds and went out. I did the procedure for resetting the MES. It reset the MES. I was happy for the moment. Then I drove the car around the block. As I pulled out the the SRS light came back on. Question, is it my cable reel in the steering wheel? How do I check it or remove it? Any help would be highly appreciated. Thanks in advance.
HondaPerson
sistar
Sep 22, 2013 10:44 PM
Daisy Lily
Feb 20, 2013 11:50 AM
mitbrown
Dec 25, 2011 08:06 AM
HondaPerson
Mar 22, 2011 10:32 AM
greenete
Jan 21, 2007 09:37 PM
