SRS reset didnt work - light still on - 97 accord
Old Mar 10, 2009 | 10:12 AM
wish234's Avatar
Default SRS reset didnt work - light still on - 97 accord
I followed the steps using http://tor.in.honda.com/Rjanisis/pub...096S23316A.pdf and the light blinked twice at the end like it says it would when its complete and erased but then the light comes right back on. What else can i do other then taking the bulb out
Old Mar 10, 2009 | 11:56 AM
hondadude's Avatar
You're in luck...the 97 models uses the Service Check Connector for the SRS code.
Jumper the BLUE 2 pin connector located behind/under the glove box.
Turn on the key and watch for the SRS light to flash.
the light will flash the 'main' code pause and then 'sub' code.
Example; long flash, long flash, pause, short flash. That is a code 2-1
http://img175.imageshack.us/img175/2...accsrscode.gif
Attached Thumbnails SRS reset didnt work - light still on - 97 accord-97accsrscode.jpg
Old Mar 10, 2009 | 12:01 PM
wish234's Avatar
ill do that right now and post my findings, thanks
Old Mar 10, 2009 | 02:02 PM
wish234's Avatar
i had 1 long flash and then 1 short flash, so i guess that its 1-1 which is "open in drivers side air bag inflator" How can i fix this ?
Old Mar 10, 2009 | 03:41 PM
The diagnostic procedure is a bit detailed to type out. The Online Manuals thread in the DIY section has links with sites that have a 94 shop manual. That manual is almost identical to the 97 accord.
The diagnostics are a bit involved. If you don't feel comfortable doing the procedure, you should take it to a dealership to get diagnosed.
Old Mar 11, 2009 | 03:05 PM
hondadude's Avatar
The most likely fault is the 'spool reel' in the steering column.
Have you had problems with cruise control or horn not working?
You will need the procedure from the manual to check this.
BE SURE TO DIS-CONNECT THE BATTERY before working on that SRS system
Old Mar 11, 2009 | 04:06 PM
wish234's Avatar
i do have issues with the horn and CC not working . either the reel is unplugged for some reason or just bad. Where can i get a new one or do i need to go looking through junk yards ?
Old Mar 15, 2009 | 03:32 PM
wish234's Avatar
changed the cable reel and that solved the issue. The horn and cruise control work now. I also reset the SRS light and its gone now . No SRS or CEL lights any more. Back to normal
drifterz73
Mar 9, 2015 02:17 PM
Hondalover
Mar 5, 2011 09:57 AM
jtnixit
Jan 30, 2010 08:27 PM
Antarctica
Jul 7, 2008 02:49 AM
Busareds
Jun 26, 2007 05:50 PM
