Stalling, please help!!
Old Apr 8, 2006 | 06:34 PM
kodit0103
Default Stalling, please help!!
Hey guys whats up. I have an 89 honda, 4d, AT. WHen the car is still running cold in the mornings, sometimes it just shuts off on me. After a minute or so i can crank it up, and off i go. This is really annoying now and i need help! I have no idea whats going on? Thanks
Old Apr 8, 2006 | 09:29 PM
lightshow's Avatar
Default RE: Stalling, please help!!
is it carb or FI? if its carb then it probably needs a rebuild. there is a little diaphram that controls the choke. now there is a vacuum hose that runs to that and that may be your problem.
Old Apr 9, 2006 | 06:01 AM
deserthonda's Avatar
how are you starting the car up?? I mean do you depress the accell pedal?? how many times ? when it starts what rpm does it go up to ? and yes is it a dx ,lx, lxi,??
Old May 2, 2006 | 01:43 PM
kodit0103
it is a carb guys. It is an lx model. When it start it, it usually goes up to about 1800 rpm, then it drops. Also, i usually only have to step on the gas once maybe, then it start right up. any sugestions welcomed!
Old May 2, 2006 | 01:59 PM
sir_nasty's Avatar
the first thing I would do is to check all the vacuum hoses going to/from the carb and around it. Make sure they are in place, wiggle them around a bit and make sure they aren't cracked or leaking air etc. If that's all fine then it could be the choke or a possible rebuild from there I believe.... check over all that stuff and let us know.
argarcia86
Jul 3, 2012 10:36 AM
redbull-1
Jul 1, 2012 03:40 PM
mamtsberg
Mar 17, 2010 09:15 PM
Julian91
Jun 3, 2007 11:34 PM
lildragon45
May 6, 2007 10:15 PM
